Forums -> Technical Support (Archived)
 Credit Notes
Posted by pedalpowerip5
Credit Notes
I have been attempting to raise credit notes........what is the best way to do this for customes who return goods and ask for a credit note instead of a cash refund?
Pedal Power Cycles Ltd
Ipswich
01473610500
Re: Credit Notes
Hi pedalpower,
Raise a new order, write in the comments that this is a credit note, add the item(s) to be refunded, mark that line item(s) as 'Returned', (if you intend to resale the item, you will need to add it back into stock manually). At this point I'd print out an invoice and give that to your customer, (save a copy in the documents section, if you have enabled it), this will show the amount owed and could be used when the customer comes back to claim their credit.
Re: Credit Notes
Just an update,
In the latest version of Easify (V3.63) you are now asked if you'd like to return a product back to stock if it is returned.
Re: Credit Notes
Thanks you. This is working very well.
Ipswich
01473610500
Posted by j.alvarez
Re: Credit Notes
I was looking for a solution for a credit note and this worked very well. I just need to edit the current Statement to a new Statement with credit notes so that the overdue amount doesn't mix up with the total amount that needs to be paid by the customer.
Thanks a lot.
