New feature for FP7 - product label designer...
Hello folks,
Just thought I'd hop on here to show you one of the updates we will be releasing as part of the free Feature Pack 7 upgrade (which will be out in May 2013)...
We're incorporating an all new price label designer that will allow you to design any size and style of price label, from tiny wee labels for use in the Jewellery business up to full size A3 labels you could slap onto crates.
The label designer will let you create as many different label styles and sizes as you want, and you can select which type to print from Easify when you go to print price labels.
Here's a screenshot for you...
[Missing attachment: Price Ticket Designer.PNG]
As you can see, you can add static text, images and Easify product fields to your labels. Any of the fields can easily rendered as barcodes.
Once we've got the new label designer out there and in the wild, we intend to extend it to work with other parts of Easify with a view to it becoming a fully fledged custom report designer. Which will allow you to create and fully customise any business reports or paperwork that can be generated from Easify.
